- Mar 3, 2004
- 8
- 0
- 0
2005-01-14 02:01:44 WARNING +12V ( 0.00 V) exceeds High/Low limits (13.74/10.15 V)
2005-01-14 02:01:49 ------- +12V (12.04 V) functions well
This is the basis of my problems. At first, I thought that this computer might be pulling heavy on the 120V line, so I installed a 1100 VA UPS unit. Still happens. So I thought it might be working the power supply a lot, so I put in another power supply. I now have an Enermax 660w 24-pin power supply and an Enermax 460w power supply in my computer. The 660w powers the motherboard and boot RAID array, and the second power supply power the case's 12 fans, as well as the other hard drives (4 others). So I thought that these might be approaching the limit of the 120v line, so I got a Power Angel (very nice I might add), and I'm pulling a steady 4.8a on 120V line, plus the laser printer pulls about the same, but this is a 20a breaker on the line. I don't know what else it could be. But every once in a while (not nearly as often now), either the +12V or -12V lines, or sometimes others, exceeds the limits, and then about 2 seconds later, returns to normal. I'm out of ideas, and I can't find really any help anywhere else, so I will try here to see if anyone has any ideas.
Is there any way this is ust normal for a power supply? It doesn't seem to be affecting anything anymore, so manybe it's like a self-check or something? I don't know.
