- Jun 20, 2009
- 2,428
- 0
- 71
Hi Guys!
I have a question about what might be causing this, but I'll give you a few details first.
First off, this will be my fourth Corsair power supply four months. The first I purchased as an upgrade in reliability (or so I thought) from a BP430. I purchased a CX500, but as soon as I got around to playing really high end games it started screeching and screaming after about five to ten minutes. Just so happens I gave away my Antec BP430 to a friend who had a CX430 die after 2-3 months as well. So I returned that for a refund from Amazon and in it's place I ordered a TX650. I figured it had plenty of headroom, so it shouldn't have a problem. It came DOA. I had Amazon replace it, figuring it was a fluke. Then about a week or so later I start hearing clicking and grinding. I figured maybe an HDD was going bad, because they are all between four and five years old. So I shrugged it off and told myself within the next few months I'd replace them all with a three or four TB drive and went on with life.
Around a couple weeks later I ordered a new case, coolers for both my builds, and fans to quiet the system down. When I was test booting, the back of the case was facing me and I heard the noise even louder with the case open. I put my ear right next to the HDDs and they were quiet as could be. I followed the noise back to the corner opposite the AC plug on the PSU. It doesn't seem to be coming from the fan, but from a red box or green cable just behind the grating on the back of the PSU. Since that was the third PSU I'd had from them, I was mad and went right straight to request RMA.
Tonight, I had to redo all of my cable management for the third time to install the fourth PSU. The same problem exists with this one. It grinds and pops on startup, loading web pages, and playing games. It seems anything that alters the load on the PSU makes it sound like rice krispies on 'roids.
Another problem I've had with both is when I shutdown the PSU or unplug it and of course plug it back in, it turns every fan on full blast and then instantly cuts the power. About two to three seconds later it kicks back on and everything (except the grinding noise) is fine and dandy.
Keep in mind I have tried a six year old TX650 both times, which works like a charm with little but fan noise. Of course the BP430 still works like a charm too I'm sure. My friend still has it in Indiana.
After all that, what do you guys think the problem is? Is it another component failing I'm unaware of? I know with one hundred percent certainty the sound is coming from the PSU, but that doesn't necessarily mean the PSU is causing the problem...
EDIT:
-Gaming Rig Specs-
Antec Sonata Solo II
i5 760
Gigabyte p55 UD3
8GB GSkill ValueRAM 1333MHz
Gigabyte GTX660Ti 2GB
Samsung 840 120GB SSD
3 x 1TB Samsung F3
Lite-On 16x DVD-ROM
EDIT:
-Gaming Rig Specs-
i5 760
Gigabyte p55 UD3
3 x 1TB Samsung F3
Lite-On 16x DVD-ROM
