POWER SUPPLY HELP
Sebring
Im just upgrading my system and i dont know whether i will need a new Power Supply. If yes, what wattage? Plz, help! Thx....
P3 500Mhz (100) -----------------------> P3 1Ghz (133)
i440BX MSI-6163 -----------------------> i815 (ASUS or MSI)
PSU= 200WATT -----------------------> ?????????????????
128MB SDRAM100 -----------------------> 512MB SDRAM133
GeForce2 GTS
4 Coolers (HDD, CPU, PSU, Case)
CD-R Toshiba 40x
CD-RW Yamaha 16-10-40
SB Live!
HDD Seagate 20GB 7200rpm ATA100
250 watts would probably be ok, but for the cost difference and because you might expand in the future I would go with at least a 300 watt.
I would not waste my time with a 200 watt supply.
A bit weak? I wouldnt say so. My current system is rockstable. It had never collapsed, frozen or gone to "blue"....
