I've been out of the new hardware game for quite a while; until yesterday, the newest computer I built was an Athlon XP 2600 on an A7N8X... and it was top of the line.
I picked up an MSI K8N Diamond Plus mobo, a 7600GT and an A64 3500 the other day. I'm not planning on doing major gaming... just wanted something new. I'm using the same RAM (1GB of Crucial Ballistix DDR500... it's plenty fast as I don't plan any hard OCing).
Also, I'm using the same power supply: Enermax Noisetaker 470W (I believe).
So anyway, the MSI takes a 24-pin ATX power cable. My Enermax is 20-pin. I can plug it in and the system boots, but the fans in the power supply aren't spinning. I'm not sure what the additional 4 pins are doing... could that be why my PSU fans aren't working? If so, would an adapter (like this: http://www.stayonline.com/detail.aspx?ID=1004) solve the problem or must I buy a new PSU?
Looking forward to your expertise.
Thanks,
Jeff
Thanks,
Jeff
