Power supply ? for Yeong-Yang fulltower
Sweden
59
Newbie!!
Have Yeong-Yang fulltower. It came with a 250W PS.
system:
MSI(6321)694D Pro-A (supports dual Intel PIII FCPGA)
1 CPU PIII 733@810Mhz
192Mb PC @ 133Mhz
Elsa Winner AGP 8 MB
ATA 100 Controller (on the mobo) w/ IBM Deskstar75GXP 30GB 7200rpm
Adaptec Scsi controller card 2903B (came with Epson scanner)
Plextor Scsi CD-R
Sony 48x CD-ROM
Fast Ethernet 10/100
Sony MultiscanG400
Could not get the mobo to work when set up.
Changed to 300W PS. Now working but lots of odd problems all the time.
Due to PS ??
Need to set up Win2k Server in a Client/Server network, only the two computers.
Win 98SE on the client.
Set up for MCSD cert lab environment.
Please recommend PS for this set up.
Thank's
Delbarton
17
I think any 300W ATX Athlon approved would do...
Check here...over 20 power supply choices.
But since you already tried two PS, could it be something else that caused the problems?
Sweden
59
Thanks Delbarton
I've had a look at the website you recommended and I found something there which I like. I do however think that there may be some imcompatibility between the memory that I use. I have one 128PC 133Mhz and one 64MB PC 133Mhz. I'ver removed the 64MB and the system seems a little more stable.
Anyway Thanks again
SWEDEn
