Power supply for this build
romka
Hey guys, I need to know what power suply is needed for
i5-2500K OC'ed to about 4.5-4.6 and a MSI 560ti hawk GPU.
There will be 8gbs of ram cl9-1600Mhz.
a non-modular PS is one in which all the power connectors come from the same small hole on the side of the unit, none of which can be detached from the PS. a modular PS on the other hand has multiple plugs in the side, allowing you to attach only the cords you absolutely need, cutting down on clutter and increasing airflow inside the case. i've also seen some PS's that are semi-modular, where the connectors that are essential in just about any situation (such as the typical 20/24 pin main motherboard power connector, the 4/8 pin CPU connector, etc.) are fixed to the PS and not removable, while the non-essential lines and connectors (such as PCIe, SATA, and molex power connectors) remain modular (removable).
CORSAIR PSU 500W 12CM ATX12V2.2 80+
CORSAIR CXV2 PSU 500W 12CM ATX12V2.3 80+
difference between these ?
Don't know. I don't find the first one listed...Need a proper model number for accurate comparisons.
I don't know where you're located, so providing accurate recommendations is difficult.
IMO, you won't go wrong buying Corsair, but in the 500 watt range, there are lots of other quality power supplies as well.
