- May 2, 2005
- 1,213
- 0
- 71
Looking for Power Supply advise for this build. 500W overkill?
AMD Phenom II X2 555 Black Edition Callisto 3.2GHz Socket AM3 80W Dual-Core Desktop Processor
http://www.newegg.com/Product/Produc...82E16819103846
GIGABYTE GA-880GM-D2H AM3 AMD 880G HDMI Micro ATX AMD Motherboard
http://www.newegg.com/Product/Produc...82E16813128458
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory
http://www.newegg.com/Product/Produc...82E16820231275
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Internet and music
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Under $500 USD
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
NOT a "fanboy" of any sort at all.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
possibly the optical drive and card reader (if it's not "built into" his current Dell, and is removable)
6. IF YOU have searched and/or read similar threads.
honestly...not really
7. IF YOU plan on overclocking or run the system at default speeds.
No OC needed....MIGHT unlock the extra cores available on CPU if any.
8. What resolution YOU plan on gaming with.
Does not apply, he is not a gamer
9. WHEN do you plan to build it?
Within the next month or so
10. Don't ask for a build configuration critique or rating if you are thin skinned.
Fire away
Okay...I am not 100% SET on the parts above if someone comes up with better/cheaper suggestion for MB/CPU/RAM, but I will say that even with the parts not listed (DVD drive, thermal paste, case etc....) it is $468.25 (including S & H and tax)
Mainly need to know if the chosen 500W power supply is overkill on this build, or if I can get away with like 350W. The ones I am "looking" at are below:
Antec EarthWatts EA-500D Green 500W ATX12V v2.3 / EPS12V 80 PLUS BRONZE Certified Active PFC Power Supply (THIS one is already configured into my Newegg cart)
http://www.newegg.com/Product/Produc...82E16817371035
Internet and music
Under $500 USD
USA
