Power supply for SAPPHIRE TRI-X R9 280X 3GB GDDR5 OC
How much Watt is enough to power up these including the GPU keep in mind im trying to keep the budget as low as possible, I dont want the cheapest psu out there i want something thats just enough to power it up.
-RAM: G.skill RipjawsX 8GB (2 X 4GB) DDR3 1600 CL9 1.35v Dual Channel Memory Kit
-Mother Board: ASRock Fatal1ty H97 Killer Socket 1150 Motherboard
-Processor: Intel Core I5-4590 Haswell 3.3GHz LGA 1150 84W Desktop Processor
-Graphics Card: SAPPHIRE TRI-X R9 280X 3GB GDDR5 OC
that corsair vx430 has only 32A on +12v rail. 32 x 12 = 384w. get the rosewill capstone 450 or 550 depending on your budget.
www.newegg.com/Product/Product.aspx?...82E16817182066
www.newegg.com/Product/Product.aspx?...82E16817182068
capstone 450 has 37A on +12v rail while the capstone 550 has a massive 45.5A on +12v rail. capstone 550 psu can run even an overclocked R9 290X so it gives you futureproofing. both psus are 80 Plus Gold rated for high efficiency. fantastic 7 yr warranty. :thumbsup:
I used that card on a Dell XPS 420 with the Dell 435 power supply, no problems. Since changed the PS to a Corsair CX650.
