Power Supply for P4
Mar 19, 2001
161
Would a 250 watt power supply be ok for a P4 system?
If not, then what's the required specs for a power supply for a P4 based system?
Thanks.
newbiepcuser
4,474
Depends on the qualit of the powersupply.
Manufactures such as enermax, antec, thermaltek, etc are good ones to use. You might want to read up on Anandtech's article on powersupplies. you don' t have to spend an arm on leg to get powersupply these days.
I would myself would go with good quality 350 watt powersupply. You never know when you might add another hard drive, a more powerful video card or more powerful case fans.
neptunefix
105
I have a Sparkle 300w that I got from newegg.com for $27 (+ 5 for s/h). It's very quiet and seems to runmy P4 just fine so far.
