Power Supply for Lian Li PC-65
arod
Building my AMD 64 system soon and am looking for recommendations on a Power Supply.
I will have an AMD 64 3000+
Gigabyte/ASUS Motherboard
1 Gig of PC3200 Kingston RAM
Lian LI PC-65
2x80 SATA Maxtor Drives in a Raid 0 config (I will be getting sata power connectors with my motherbaord but builtin ones would be preferred)
I want something fairly quite but it seems all the higer end ps's are.
Im on a budget on 75 bucks.
antecs are good, but to fit in the pc-65, you will have to remove the grill off the bottom fan and then put it back on once you fit the ps in. enermax ps have their bottom grill slightly recessed, so they'll slip right in.
Another way to get your TruePower PSU (or another PSU that's got a fan grille protruding from the bottom) into your Lian-Li is to lift it into place from the motherboard compartment. Personally, I like the three-year Antec warranty and the black Molexes on the Antec's wiring (plus they now come with SATA plugs), so that's what I get... Antec TruePower430.
Originally posted by: azntiger0586
with that budget, i think antec 450 or antec true430 would do.
I agree 100%. Antec makes fantastic PSUs. I have the exact same case, and my Antec 400W PSU fits in there beautifully. 🙂
