Power Supply for GTX 460
MRGOOCH
2,292
Can I get away with using a 400 watt PU unit with this card?
Case: Antec SLK 3700 AMB Mid Tower
PSU: XFX -XPS 750W Black Edition
CPU: Intel Core 2 Duo E440 Allendale 2 GHz
HS: Artic Cooling Freezer 7
Mobo:Gigabyte GA-P35 LGA ATX
RAM: 4GB Crucial Ballistix DDR2 800
Optical: Samsung SH-S222 IDE 22x DVD/CD burner
Storage: Seagate ultra/100 7200 RPM
Display: Samsung Syncmaster T240 24"
Windows 7 32 bit
narsnail
21
Whats the rest of your system like? Depending on your other components you may be able to.
What is model of the power supply? You will need to make sure the 12v Rail has enough amps for that card as well.
JimmiG
2,024
112
Yes, that really depends on what the rest of your system looks like, and also the model of PSU. Some cheap 400W PSUs are really crappy, and are in reality only like 250W. Also, many older power supplies (before high-end GPUs started drawing such large amounts of current on the 12V rail) were 5V-heavy instead.
My system is fine with the Corsair VX 450W PSU, which has 33A on the 12V rail.
narsnail
21
^Exactly, is it a PSU from some pre-fabbed Dell or Acer, or is it a decent PSU from a name brand.
narsnail
21
LOL, if it were from a Dell, he'd be fine. You don't know much about Dell, do you?
The point was most pre-fabbed units would have a useless power supply because they just need to run the basics.
EDIT: I retract my snippy comment, after actually looking into Dell PSUs.
Seero
1,456
That depends on what other stuffs you have plugged into the PSU, and the age of the PSU.
If it is new, haven't overclock, less than 3 USB plug in at once, less than 4 fans, no fancy lights, and 1-2 HDDs, then yes.
What you need to be careful is if your PSU have 1 PCI-E power cord. Mixing it with the molex cords may not create enough amps to push the card.
MRGOOCH
2,292
My PSU unit is a 3 year old Antec SL400
If I am reading the label correctly it has 18A on the 12v.
Windows 7 32 bit
Rifter
751
corsair 400CX yes.
Your PSU Hell No.
Your PSU is a 216w as far as its 12v rail. 12V 18A = 216W, calling it a 400w is bullshit
for example
Corsair 400CX 12v 30A = 360W on the 12v rail
toyota
12,957
6 years on a tech forum so why all the vagueness? you should know that a power supply is for the whole system so list your specs when making a thread like this. heck you were even asked to list your specs and still never did.
Aug 11, 2008
10,451
642
If I am reading the label correctly it has 18A on the 12v. Any feedback on this? 1 HD. Not overclocked.
Are you sure there is not a second 12v rail or something. I have an Acer with a generic 300 watt PSU and it says 20 amps combined on the 12V rail. I would think your PSU would be a lot better than mine.
Lonyo
21,938
I just looked at the online spec sheets.
It's a really cheap PSU.
* * +5V and +3.3V combined output: 240Watts max.
* * +5V, +3.3V and +12V combined output: 380Watts max
It's not even a real 400w PSU.
(http://www.antec.com/specs/sl400_spe.html)
MRGOOCH
2,292
I have decided to replace it with a:
XFX Black Edition 750 Watt
EVGA GeForce GTX460 768MB DDR5
Rifter
751
That is a great PSU, might be over kill but who am i to talk overkill, i just bought a 460 today and i have a 850W Corsair.
