- May 22, 2005
- 123
- 0
- 0
I have a DELL DIMENSION 4300 that I use all the time. I've had it for about 4-5 years or so, and pretty much leave it on ALL of the time.
Anyway, I've been having this problem where the screen goes blank, and the computer is unreponsive. The power light goes AMBER...it is impossible to power down the computer with the power switch...I called Dell...they told me to pull out the power plug in the back. When I started up the computer again, everything was ok.
This has happened about 10 times in the last couple of months. It is super annoying. I researched a bit, and AMBER power light indicates power supply problems.
Dell can sell my their power supply again, but thought I would ask here is anyone can recommend a really good power supply for a DELL DIMENSION 4300, that is left on all the time, and runs important business applications.
Or if you think it is better just to buy the one DELL sells...pls let me know that.
Thanks everyone!
quanttrading
Thanks everyone!
quanttrading
