Power Supply for Asus a7n266-vm ,xp 1800+
jayu
21
I ordered Asus a7n266-vm motherboard and xp 1800+ processor.
one cd -rom drive. Graphics and sound integrated in mobo. In future may be addtion of cd writer. and 40 gig hd. right now i have 6gb old hd.
I have a micro atx case. So I need a Micor atx p/s.
Questions.
1. What watt p/s needed like 250, 350, etc.
2. Any suggestion for micro atx p/s ?
3. Do I need a atx p/s?
mechBgon
Oct 31, 1999
30,699
microATX and standard-ATX power supplies have the same 20-pin primary connector, so you can use either style if your case allows either style. What case do you have (brand & model)? Some microATX cases, such as Fong Kai, Inwin and Enlight, often have room for either a full-ATX or mini-ATX power supply.
As far as wattage goes, I would recommend a PSU that can put out 200-220W on the combined 3.3V + 5V lines. For many companies, this is their 300W PSU, but it varies a lot from brand to brand and model to model. Sparkle Power has a good 300W ATX unit at Newegg.com for $27, if it's back in stock again. If your case can take a full-sized ATX power supply, that would be a good starting point. If you plan to add a powerful video card later then it might be a good idea to go a little higher, with a Sparkle Power 350W, or an Enermax 365W, or an Antec TruePower 330W.
