Power Supply for AMD 1.33 & Epox 8k7a ?
whistleclient
I was thinking of getting the new Antec 630 case -- 300W PSU
or an Antec 635 -- 350W
Or I get it without a power supply and put one in from Fry's.
any suggestions?
drives are getting cheaper and cheaper (slowly) so i suggest the strongest PSU you can afford, i just got rid of my 300W for an enermax 431.
431 Watt booty
300W will be perfectly adequate...now adays on this board bigger PSU is what the nerds think translates to who has the biggest shlong.
The Antec 400w P412 is good. DO NOT get enermax as they have problems providing enough amperage on the 5v rail. The best part about the Antec is that it has pots so that if the voltage drops you can adjust it inside the PS.
Linkage
<< DO NOT get enermax as they have problems providing enough amperage on the 5v rail >>
Nothing wrong with Enermax, the 350w is now officially on the AMD approved PSU list up to 1.4ghz,I use Enermax &amp; so do my friends all on AMD systems with no problems .
<< 300W will be perfectly adequate...now adays on this board bigger PSU is what the nerds think translates to who has the biggest shlong. >>
Add the people at AMD with this list of &quot;nerds&quot;. Antec's 300 watt power supply is NOT rated for any AMD CPU over 700 MHz. errrrrrr.....
EDIT: (Good read MEM my bad!!, see below): correction: over 900 MHZ (but most people are buying CPU's 1GHz and above)!!!!
AMD Approved Power Supply Link
<< Add the people at AMD with this list of &quot;nerds&quot;. Antec's 300 watt power supply is NOT rated for any AMD CPU over 700 MHz >>
Antec PP-303X 300 W N 150 W ATX View
Contacts Athlon 900 Athlon 850 Athlon 800 Athlon 750 Athlon 700 Athlon 650 Athlon 600
are you sure? 😉.
