My setup:
1. Any chance this card would run on my current power supply, not overclocked?
2. If the answer to #1 is no, are there any GTX 460 cards that would run without any problem?
3. If the answer to #2 is no, what cards are recommended below the 460 that would work with my existing power supply? I'd like to keep the cost to a minimum if possible; I've already changed several components in my machine to try and get this thing working!
Thanks in advance for any advice!
Moved to PSU forum.
Super Moderator BFG10K.
- GIGABYTE GA-EP45T-USB3P LGA 775 Intel P45 USB 3.0 ATX Intel Motherboard
- Intel Core 2 Duo E8400 (Wolfdale) 3.0 GHz, with a Zalman CNPS7000C-Cu Cooler
- G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600)
- BFG Tech GeForce 8800 GTS (G92) 512 MB (ForceWare 258.96) (Died a sudden death)
- Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA
- Corsair CMPSU-620HX 620W Power Supply
- Windows 7 Home Premium 64-bit
Moved to PSU forum.
