Originally posted by: JBird7986
Quick question, because I also bought an 8800 GTS 640MB. For power, I bought a 550W Antec NeoPower power supply that's SLI certified. However, I've got three 12v rails with 18amps on each. Will this power supply suffice?
More then likely. From what I am reading different manufacturers have different requirements for their video cards. eVGA seems to want a lot of amperage from the 12v rail, I do not know who makes yours so I can not vouch certainly for yours.
That said, I am more then certain all PSU manufacturers allow for over drawing on the 12v rail, take my video card for instance. Requires 26amps from the 12v rail, even though the PSU I have is only rated at 18amps like yours, I am more then certain it can crank out the additional amps.
However that said, overdrawing of any of the rails can cause one of two things to happen, or both. Your OL protection can start to degrade over time and you'll trip your PSU quite a bit after extended use. Or secondly, overdrawing of the 12v rail will severely shorten the life of the PSU.
As I said earlier, I leave my computer on 24/7. So I not only want to meet the video cards requirements, but I do not want to overdraw on the 12v rail shortening the lifespan of my PSU. I need it all to run smoothly for the life of my computer. Your needs might be different then mine.
I owned Enermax PSU's on past builds, the older models I can say are very reliable. Same with Antec and Vantec for that matter, I do not know about the new ones. I normally choose PSU's with high amperage on the 12v rail in the past as for some reason on P4 systems and older, required a PSU to crank out the ampage for more stable OC's when stuffing 12v into the motherboard became standard over the older 3v/5v. However my most recent one only had 24amps on the 12v rail, and is not compatable with newer systems as I got it in the S478 era long before SATA and PCI-E standards were nothing more then a design concept. This is my first time I ever had to get a PSU with such high 12v requirements just for the video card. I figure I'll also need the addional amps because I still OC all my systems.
Basically here is the system specs of the parts I have so far.
P180 case
Asus Commando motherboard
eVGA 8800GTS 640mb version
SATA DVD writer
IDE DVD-Rom
52-in-one card reader
CPU is yet to be determined, I think I am gunna get a e6600 or a cheapo celeron... see below.
Memory, I am still a little uncertain about. I think I am gunna get the dominator 8500 sticks, or just go cheap on memory for the time being and wait for the new x38 chipset motherboards to come out and go with DDR3. Hard to say as I already have the motherboard and x38 will not be out till the ending of this yearish time frame. But the thought of a celeron is appalling.
Hard drives will likely be 3 x 750GB seagates unless Hitachi gets off their lazy bums and cranks out the 7K1000 hard drives, in that case I'll get 3 of those. They have 3 1/2 weeks to get them on shelves.
