Power supply fan facing side ? a problem ?
northZephyr
19
Hi
Just a little thing I noticed when completing my build :
THe power supply I chose Corsair 620HX Link
must fit in to the case I chose : Antec 900 Link
But the case offers a bottom-PSU socket... is there going to be a problem if I place the PSU upside down so the fan could face upward ? ('cause reading comments, many ppl say the fan is facing downward...
Thx
PurdueRy
13,837
4
Originally posted by: northZephyr
Hi
Thx
Turn the PSU "upside down" and magically the fan will face upward.
jonnyGURU
Moderator <BR> Power Supplies
Moderator
Oct 30, 1999
11,815
104
Exactly, unless the PSU is liquid cooled, gravity has no effect on it. ;)
Flip it around so the fan points up.
HOOfan 1
2,337
15
Originally posted by: Scoop
I'd rather cut a hole in the case below the PSU than turn it upside down.
why? Other than the logo being upside down it makes no difference.
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
Exactly. Why? So it can suck up dust bunnies off the floor?
The PSU would be sucking in cooler air since it wouldn't be sucking in off the graphics cards, but if you have a decent PSU it shouldn't make any difference to it's output capability or longevity if you have an appropriately sized PSU to begin with and case temps don't exceed 40°C.
imported_Scoop
773
Well that was my point in the matter. Maybe a full-blown hole is a bit too much but some smaller ones for the PSU to breath through. I clean my apartment pretty often :)
Has it been tested that it has no effect? I just thought that it MIGHT trap some air inside the PSU as the airflow isn't designed for the PSU to be upside down and the hot air would try to escape through the fan.
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
You using forced air to begin with, so the "hot air rises" theory doesn't apply. The air is going to push out the back with the fan up just like it would with the fan down.
