I am THRILLED with how quiet our newly acquired Pavilion a530e is, which uses the ASUS A7N8X-LA mobo. I'd like to upgrade our other PCs using the same combo of A7N8X-E Deluxe, CPU/HS/fan, and case fan (whatever brand that thing is). It's using an obscure power supply, but it's able to control the PS fan via the mobo, without connecting to a mobo fan connector:
ATX12V-250HPC
ATX12V-250HPC
- This ATX12V power supply is a 250W, PS2 Form Factor, six output unit with remote on/off, and UL, CSA, CB, TUV, NEMKO and CE approvals. Does not require 3 pin connector for board control of power supply fan. Airflow drawn out of case into surroundings by 80mm ball-bearing fan. Aftermarket product suitable for HP part numbers 0950-2700, 0950-3971, 5183-6914 and HP/Compaq part numbers 5187-1098, 332863-001. Upgrade for Delta DPS-200PB-74 B, LITEON PS-5151-2H3, and Bestec ATX-250-12V.
