Power supply check
Raloth
System
Motherboard: Intel DP965LT (no overclocking)
CPU: Intel E6400
RAM: 2x 1gb Corsair Valueselect 667
Video Card: Radeon x1800xt
One harddrive, one optical drive
Originally I was planning on the Fortron AX400-PN. The eXtreme PSU calculator spits about 350 W maximum at me, before any surge protection or capacitor wear. What I'm not sure is if the amperage is enough. Am I better off going with the AX450-PN? Any similar quiet PSU I should get instead? I know this gets asked a hundred times a month, but man is it confusing when you're doing your first build. Thanks for any help 🙂.
Originally posted by: dBTelos
Here:
http://www.sundialmicro.com/SilverStone-Power-4000Watt-sstst405_1753_590.html
SilverStone Strider 400W
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=270340
Enermax Liberty 400W
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=271602
Seasonic S12 430W
The parts in the AX model number Fortron's arn't as great as FSP parts.
What's the main difference otherwise then? Apart from the Enermax, they all seem to have lower specs.
