Hello,
I am building 3 new computers, all identical except for different sets of 4 GB DDR2 memory. Two are for family members and one for us. I am using the following:
1. Antec Sonata Plus 550 (this one has Neo 550)
2. Asus P5Q Pro
3. Q6600
4. OCZ reaper, Corsair or Patriot 4 GB memory (2 X 2 GB modules)
5. Samsung 22X Lightscribe burners
6. Samsung 500 GB SATA HDs
7. Sony 3.5" internal card reader
8. PNY 8800GT cards
9. One extra 92 mm intake fan on the Sonata Plus
10. Vista Home Premium 64
I started on all 3 units yesterday and installed MBs, drives, CPUs etc. However completed one unit testerday and all went well. So I put it away.
Finshed the remainder of the second unit this evening and turned it on. The green LED on the P5Q Pro lit up, but nothing else. How can I test the PS to determine whether it is bad. This is what I did - and I feel I am missing something: I turned the PS switch off and then unplugged the 8 pin power connector. It is supposed to have +12 volts on 4 pins on same side and ground on the other 4 pins. My voltmeter read 0 volts. Perhaps I am not testing it correctly. I unplugged the connector and then turned the power on. Then I tested it with my voltmeter, but no readings. I have not tested the 24 pin connector as yet.
Hopefully it is my PS, not the MB, as it will be a pain to redo everything. Any help is appreciated.
aba4430
2. Asus P5Q Pro
3. Q6600
8. PNY 8800GT cards
aba4430
