might be a noob question and possibly I did something stupid.
I bought a new ps since my old one died, but I noticed it has a 24pin connector for the motherboard. I'm able to remove part of it 4pins to make it into a 20pin connector which fits into the motherboard. the pc turns on and works fine
but do I need to use the 24pin -> 20pin adapter to connect to a 20pin motherboard?
if the adapter is needed why make 4pins of the 24 pin connector removable?
anyone know?
anyone know?
