- Feb 23, 2007
- 4
- 0
- 0
Hello
I have recently been build a new system and its been working great for me. I haven't finished all of the components I want installed in it as of yet. I plan on installing two 150 Raports in Raid 0 and when the GeForce 8600 Ultra's come out I plan to get two 512MB cards and SLI them and possibly a physx card (my board has a 3rd PCI Express x8 slot for this but i'm not sure if I'll get a card.) I want to know two things
1. When doing SLI if I have two 512Mb cards will the computer recognize it as 1GB of Video memory or will it recognize as only 512MB.
2. I wanted to know if the current power supply that I have would be able to hanlde all of these components. In the end this is what my build will be
Asus P5N32 E SLi Nforce 680i Motherbaord
Intel Core 2 Duo E6600 2.4ghz @ 3.22ghz
4 GB of Crucial PC2-8000 DDR1000 @ DDR1015mhz
2x 150 WD Raports @ Raid 0
1x 250 GB HD (and possible 1 more 250GB of the same kind which would be probably in JBOD to look like one big disk)Samsung 18x DVD Burner (Internal) SATA
Thermaltake Hardcano Fan Controllor
2x 120mm Case fans
Zalman 9700 LED 110mm CPU Fan
**When available** 2x Nvidia GeForce 8600 Ultra 512Mb SLI Configured
I also have a vary of USB decied connected but the printer is the biggest one then everything else it just small powered stuff and I have to 2x 19in NEC monitors running as one big desktop with the taskbard on the left monitor and a full screen on the right monitor working as one desktop.
This is the current power supply should I buy a new one with the outlook of this final build.
Antec NeoPower 480
Thanks for your help
2x 120mm Case fans
Antec NeoPower 480
