Power supply 24 pin missing one?
nervx
43
Quick question. I was removing my corsair hx620 to put it in my new build and noticed a pin missing on the 24 pin connector. It's the 5th pin in and it isn't attached to a wire. I also found this small 1.25" metal tube. The metal is round not squared like other pins. Is this piece supposed to be in the empty connector spot?
Edit: please ignore this thread and Thanks postmortemIA. Figured out the metal rod was from a fan and not the 24 pin.
