power supply +12v rail
mrd2689a
7
Hi. I just built a new pc, you can see the specs in my signature. I am having a problem with my +12v rail. In Core Center, which I use to monitor my motherboard/cpu, I am getting a reading of 11.66v on the +12v rail. Is this bad? Is there anything that I can do to get it up to 12v? Thanks a lot!
Matt
D1gger
5,411
I have the same issue with my PS when looking at ASUSProbe. The 12V looks like 11.6V, but when I look in the bios is is pegged at 11.89V. The software monitoring tools are notoriously inaccurate. I would check the reading in bios.
mrd2689a
7
D1gger thanks for replying so quick
You just gave me a big a$s boost of confidence, I'm going to check my bios :beer:
Thanks a ton! Illl report back in a few
Matt
Raj
951
usually there is a small variation in the voltage, and it is never exactly 12v. I would suggest watching it and if it goes below 11V then you may want to try replacing the power supply. Otherwise I see no reason to worry.
mrd2689a
7
Hi again
I just checked my bios and I am very happy to report that in the bios, my +12v rail is at 11.98something. WOO-HOO!:)
However, I did just think of something. Could this be because the cpu is under such full load at the bios (that is why the temperature increases steadily in bios; bios is written in a very low-level code, it can even heat up a A64, which it does). Does the fluctuation of the +12v rail have a correlation with the activity of the CPU (how much it is performing)? Please post back soon. Thanks again!
Matt
mechBgon
Oct 31, 1999
30,699
My usual suggestion is to check the PSU with a multimeter if there's any doubt about the output. Got Fluke? :)
Bassyhead
4,545
Yes, software monitoring tools are notorious for being inaccurate. A general rule of thumb is that the voltages should be within 10% of the required value. In this case, 11.66v was still ok as it was less than a 3% deviation from 12v.
