POWER SUPPLIES
jerryjg
Banned
hi, will any power supply work with my P>C. ARe there special requirements? I am running a 350volt power supply and would like to upgrade to a larger one before i do some cpu/mobo /hdd upgrades. what do you reccomend? what is a great value for the money in terms of quality and performance? thanks
I have an ENERMAX All in One Noisetaker Series EG701AX-VE SFMA(24P) ATX12V 600W PSU and it seems to work great. The thing I learned when buying new power supplys is to look for the new pin setting on the motherboard. 24 instead of 20. Do not use a converter to goto 24 from a 20 pin.
PKing
Seasonic, Enermax, Tagan. Tagans happen to be my favourties for various reasons however.
Any of those (and any power supply generally) will work. Although if you're looking to use SATA drives+generally newer connection types etc then a more modern one (as those above) would suit you best.
I think the Fortron Blue Storm power supplies are great value for your money, it's something like $70 for 500 watts. Although they are not the quietest around, they do have the best efficiency you can find.
