Power Supplies.
Hajime
617
I've been reading these boards for a bit, as well as other sites, and I've been hearing not-so-good things about Thermaltake power supplies.
I've been looking at this PSU for a while, but am beginning to reconsider.
For the price and features - Active PFC and 480W for under $70? - it seems like it is excellent.
However, I've been hearing that TT PSU's are basically crap on these boards...is that true? What's up with them?
Hajime
617
Only thing noted on the Newegg specs is effic. is > 65%.
I'm just really looking for a reliable PSU to last me for a while - the Thermaltake's specs seemed like they'd be good. Tempted to go with an Antec Neopower, but I note that the Neopower isn't even listed under silentpcreview.com's listing either.
0roo0roo
64,795
84
its too bad silentpcreview doesnt seem to have a review of it. specs are just unreliable without atleast a review to confirm them as true. too many ways to be shady with both power and noise level specs. ilike the seasonic tornado/supersilencer series(both are quiet despite the formers name). good specs and super high efficiency+pfc. so its quiet, cool and uses less electricity. costs more in the short run though:p
Nessism
1,619
I just bought an Antec 480 from Directron.
Antec up the spec on the 12V rail for their True series units; mine came in at 28A:)
Upgraded an older Antec 400 Watt'er and the 480 is MUCH quieter. The new fan speed controler really works!
Not cheap, $80 + shipping, but the peace of mind is good.
Ed
Maverick2002
4,694
FYI active PFC won't make your PSU any more efficient or save money on your energy bill (unless you're charged for apparent power and not actual power), it just keeps the mains clean. Still a good thing to get though.
Gamingphreek
11,679
I would highly advise that you do not buy thermaltake.
They use flashiness over quality. Get either Enermax, OCZ, Antec, Silverstone, Seasonic, ANYTHING besides thermaltake.
-Kevin
Maverick2002
4,694
I have no experience with TT. Seasonic and Enermax have the highest efficiency PSUs and personally I would go with one of these. Antec is also a good brand.
MichaelD
31,528
You get what you pay for. There will always be some users that report bad experiences with any powersupply. But, I have never had any probs w/Antec powersupplies even when, IMO, I was overloading them. I'm sure others will echo this finding.
Don't buy a powersupply b/c it has cool graphics and cool gold grills and dope neon lights. Buy a powersupply based on it's ratings and reputation.
MichaelD
31,528
Originally posted by: element
I got this one at a local B&M a couple of months back when my antec blew out, and it's been solid since.
Your timing and choice of powersupplies is very curious. ;) Particularly based on what I just typed, verbatim.
I really like this astute user review of the above PS:
A Power Supply Should Be Wired Up To Your System Before
You Turn It On Cause The Mother Board Controls Power Demands
He's really intelligent; sometimes I turn on my system BEFORE I wire up the power supply...it never seems to work too well. :D
element
hehe yeah I just noticed what you wrote after posting mine. I didn't buy it cause it looks cool, I bought it because it was on sale at the B&M store I was at. It was the lowest priced highest power rated unit there. I was a bit nervous at the no-name brandedness (well at least a brand I didn't recognize) but it worked out well.
The antec that blew was a 340 watt IIRC, this one is 500W. I visited that PSU calc page (can't remember the URL right now) and calculated my PC was drawing about 330W. Go figure.
element
well those noobs are arguing with each other over someone that posted his PSU 12v rail ran under 12.0v and astutenoob there says not to test the voltage with a voltmeter without connecting it to a working system first.
MichaelD
31,528
I was just giving you crap. :D The timing was just...perfect! :thumbsup:
cessation
178
After all the power supplies I have replaced in past 3 or 4 years I had to post from my past experience. About 4 years ago or so My PC kept reseting, I couldn't figure out why. I started reading on tomshardware that you need to check the rails and make sure you have enough power on each rail.
Rails are the lines that say +3.3V@30A;+5V@40A;+12V@18A . A lot of new PSUs have dual 12v lines now because of new systems, CPUs etc needing more power and most older PSUs can't handle it.
I have replaced 3 antec PSUs that had under +20v@18A, and antecs are good PSUs.
Anyway anyone's PC that I have to replace a PSU I usually make them get a PSU that's a enermax or antec and has a good even 30A on each rail/line.
I have tons of components in my pc and never had any problems with the last 2 PSUs I bought for myself.
One of them is enermax with 32A on each line and another is a server enermax PSU with 36A. The server enermax was about 150 or so but well worth it if you have tons of components I think.
Arcanedeath
2,822
Try and get @ least 20A on the 12V line from a quality manufacturer the PSU you listed only has 18A on the 12V rail, thats a bare min. for todays systems if you try and power some of today's higher end systems that draw alot on the 12V rails you could have issues w/ most of the PSU's listed in this thread save the Antec 480 so far, I'd look into somthing from Antec, Enermax, Seasonic, Fortron / Sparkle (FSP), or possibly OCZ new PSU's and get something w/ at least 20A on the 12V rail.
apoppin
34,890
alienbabeltech.com
-Kevin
Why NOT Thermaltake?
Personal opinion? . . . . bad experience? . . . any links?
I have one. it is a decent, quiet and stable PS.
i believe it was reviewed on AT and got good reviews. ;)
Gamingphreek
11,679
Thermaltake used to be an awesome** company. The last time AT reviewed a PSU was in that time period. But within the last year or so they have gone down going for flashy looks over quality.
They just cant touch the top 3 OCZ, Enermax, and Antec.
-Kevin
