I'm gonna be building a pc in a month or so, and I'm having a bit of trouble picking out some components. Any help/advice would be greatly appreciated. Priceis a pretty big issue at the moment, but I want to try tomake the best PC I can withen my budget. Here's what I'm looking at:
-Athlon XP 1800+ OEM
-Soltek SL-75drv5 kt333 Socket A
-PC2100 256 mb DDR (planning onb upgrading this in 6 months or so)
-Netlink 320K 18" 300W ATX case
-Volcano 7 fan
I'm gonna also be getting a DVD drive, and carying over my HDD, CD-RW, and Geforce 3 from my current PC. My main two concerns are:
-Will the 300W power supply be enough? I've heard somepeople having problems on XP systems with less then 350W.
-Heat. I know the Athlon XP's run hot, but is the Volcano 7 really necessary if I'm not planning to over clock.
I was also wondering if it would be wise to wait a couple months before purchasing these components. How close are the next lines of Mobo's and processors to being realeased? If there as a price drop it would make my decisions sooo much easier.
Thanks for all you help.
-Volcano 7 fan
