POWER SUPPLE HELP ! SETTING ! SERIOUS HELP !
smokeybanana
Hi! I dunno what power setting to do for my computer. My Computer is:
msi k8n neo4 platium
1 Ghz Ram
leadtek 6600 gt 128 mb
Like, I know that on * CPU VOLTAGE * i can choose + 3.3 % Or +5% or 8.3 % using the CoreCenter program. My PSU is a Antec Smart power 2.0 500 WATT! Is Higher Better ? Like should i choose 8.3 % ? What's +3.3V = 32A ? Can anyone explain to me about this ! i need help ! thx
leave it as is. Don't up the voltage unless you are experienced with overclocking, which you are not 😉. 32A is the current on the 2.2V rail. Don't worry yourself with all this, it won't affect your performance
Agreed...leave it at default. Also, in your post title, please dont use caps. It's hard to read and is considered equivalent to shouting.
