nisryus
Yesterday I was changing my backup car, a 2004 Corolla, and saw the power steering reservoir needed refill. That was strange since it was full a month ago. Looking to the area below the reservoir I saw splash of oil/fluid everywhere.. Uh oh, the thing was leaking all these time. Went to Autozone and got some UV dye and put it into the reservoir and then test it. Found that there was a small leak between the hose and the pipe that connected to the pump. (i can't find any image on line and wife took my camera). i found a pic here in this alfa romeo forum though.)
http://www.alfabb.com/bb/forums/353431-post4.html
The leak is where the hose (number 5) connects to the pipe that extended from pump (number 7) I thought maybe the hose clamp was loose, but if that was the case the pressure should have pushed the hose away already.
Should I just replace the whole thing or get a new clamp?
