Power Shot: A650 IS vs S5 IS
Mir96TA
1,950
37
Beside Optical Zoom on S5 IS and 12 Meg Pix on A650
What else is the big difference ?
O yea S5 IS have Stereo Movie Recording.
I do not how much of Mega Pixle can makes difference
Hotshoe for Flash
AnitaPeterson
6,021
547
A year ago, I had to choose between a S3 and the A640... I chose the S3, never regretted it one bit. I don't see how the tables could've turned. The S3 is one of the best cameras I ever came across.
Fardringle
9,200
765
It really depends on what you want. I would agree with Anita that overall the S5 is the better camera out of the two, but if you want something that will fit in your pocket it might not be the best choice.
Mir96TA
1,950
37
S3 :confused:
There is no S3 Camara
I think I have made my mind S5 IS the Right Choice for me
Krioni
1,371
Originally posted by: Mir96TA
S3 :confused:
The S3 IS is the previous model to the S5 IS. There is great debate as to which provides the better image quality (look on dpreview.com ). They have the same size sensor, but the S5 has a higher pixel count.... this can sometimes (often) lead to more noise in images.
Anyway, I think you'll be happy with either camera. The S3/S5 cameras do take pretty good looking video with stereo sound as an added bonus.
Jawo
4,125
If you are leaning towards the S5IS I woulf get it. It has so many features, plus the super zoom. The only reason to get the A650 would be for compactness as the S5IS is rather chunky.
AnitaPeterson
6,021
547
That would be the ONLY downside to it...
Aharami
21,205
165
dunno how much bigger the S5 is, but Ive managed to fit the S3 in my jacket pocket. No luck on pants pocket though :(
alkemyst
83,769
19
I was in the same boat and went 650IS...size was the factor. If I was going to go larger I would bypass the S series for G. A much better setup.
