Thank you Woodchuck. Also thanks to Lian-Li.
We can get there from here.
Picture of the Lian-Li connector. Another picture.
Takes a few minutes of effort on our part though.
Need to badger, bother and berate Enlight, Antec, Chieftec, Enermax, Superpower, down the line to also include such a connector. Thing is, it needs to be the SAME connector with the same pinout, if they come out with a different quick detach we need to write them again and say "That was nice, however". Year from now if all new cases are coming out with a quick detach it'll be viable for a motherboard maker to put a matching plug on their boards. As far as reverse compatability, until the case manufacturers start leaving out the second part of the wire there's no problem, and at that point there will be enough around that if someone wants to put together a retro BH-6 in a 2005 case they can find the appropriate cable or will have a few lying around. The other reverse compatability problem is if someone is still using their old case at the point where motherboards no longer have pins - again easily enough solved by the use of an adapter. It'd have the female side of the plug and instead of the female two pin connectors it'd have to have the male ones. Doesn't currently exist, but would be really cheap and something any retailer selling motherboards wouldn't have a problem holding in their inventory. I don't know that I'd go so far as to say it should be included with motherboards in the future, though the first generation to use the single plug might be well advised to include them. At which point we're back to many people having them lying around and giving away to those who might still need one for their old case.
Again, same connector as Lian-Li is currently using and of course the first part of the wire harness will have to be long enough to reach the corner of the motherboard where the connectors are found, something I'm not sure about with Lian-Li's current wires. Woodchuck could probably tell us that if he's still reading.
Now the hard part, who will join me in some badgering? No fame or glory, just the satisfaction of knowing you did builders around the world a favor if we get the case manufacturers talked into it.
We'll work on the screws later...
Any volunteers? I'll gather (and gladly accept) contact emails if there's support. Let's use the power of the Anandtech Effect for something other than scaring small retailers with links from the Hot Deals forum
--Mc
