I'm building a new system and have run into a problem. I have one of the Chieftec cases from Newegg, it has a three pin connector for the reset button and two pin power button connector. The Albatron board im using has a 2 pin reset and 2 pin power connector. How can i hook this up? Pins 2-4 are reset and 6-8.
It's a KX400+Pro board
Thx for any help Oh - black is ground and red/green are just +5 +3.3 etc with these connectors right? The power connector is green and white? What are these designations as the board has a + and - connection for them.
Located power connector (doh) It was lodged behind hard drive chassis in case.
I disconnected everything but the motherboard power connector and still nothing! No fan movement or lights of ny kind except a little red light on the mb it goes out a few secs after removing power.
Repeat help!
Repeat help!
