- Sep 5, 2003
- 19,458
- 765
- 126
NVIDIA recommend a 350W-400W power supply (22-26A on the 12V rail) for the GeForce 7900 GTX, while a 300W-350W power supply is recommend for the 7800 GT (20-23A on the 12V rail).
I hope this helps to anyone concerned with their older PSUs. A PSU I can recommend is ENERMAX EG651P-VE FM(24P) 550W It has 36A on 12V rail, and it has been shown several times that 1 strong 12V rail is better than dual rails for SLI cards.
Cheers.
EDIT:
Ultra High-End SLI PC - with dual core cpu
You must have a power supply that can provide a minimum of +12V @ 22A of dedicated power for the two graphics cards. Of this 22A requirement, +12V @ 5.5A must be available to each of the two PCI Express 6-pin auxiliary power supply connectors. The remaining 11A must be supplied to the motherboard for dedicated graphics card use.
High-End SLI PC*: FX-57, nForce4 x16 SLI, 2 HDD Raid 0, 2GB RAM, 2 optical drives, one PCI sound card
Minimum of 500-600W Power Supply with a minimum of +12V @ 30A for all PC components.
Mid-Range SLI PC*: ie. A64 4000+, 1 HDD, nForce 4SLi, 1GB RAM, 2 optical drives, one PCI sound card
Minimum of 450-500W Power Supply with a minimum of +12V @ 26A for all PC components.
Low-End SLI PC*:
Minimum of 400-450W Power Supply with a minimum of +12V @ 22A for all PC components.
Source: Firingsquad
Full System Load
TechReport - Power Consumption @ Load - includes SLI
Anandtech - Single Cards
Cheers.
EDIT:
Low-End SLI PC*:
Source: Firingsquad
Full System Load
