Power question
bfozz
will a video card that requires 450w work with a 500w power supply
Video Card is a asus x1900xt 512 crossfire
i have a asus m2n sli am2 mobo
amd 4200 x2
1 320gb sata hard drive
and 1 cd burner
i am having problems with the card sending a signal, i plugged in an x800 card and still nothing happend
help please
sisq0kidd
17,043
A video card requiring a 450w psu should work with a 500w psu, unless the power supply has some issues with keeping volts stable.
Doesn't sound like a power problem to me. Sounds more like you have an issue with either your processor, motherboard or video card just not working rather than your psu.
Did your system work before hand or is this a new build? Also did you change any components before it stopped working?
Edit: Ok, judging by your other thread (which you should consolidate by the way), you are receiving beeps at startup. Does the motherboard also beep when you put in your x800 card?
Also, make sure you have that pci-e power connector connected to your video card.
bfozz
yeah so far with both cards the computer beeps, and i did buy that power connector.
this is a brand new rig
