Originally posted by: psteng19
Anyone have any recommendations on good power protection for home theater equipment?
I imagine anything good enough for a PC is good enough for a home theater, no?
Is it common practice to use UPS for home theaters?
It makes sense but seems overkill considering you don't really need the backup power to save work and shut down properly.
Absolutely NOT. Avoid PC type UPS systems (at least the low-end ones), because they don't put out a true sine wave. Home theater products aren't built with the same switching power supplies that are able to accept stepped or approximated sine wave output.
In terms of a surge protector, a whole house system may be the best choice if you want protection.
Unless you have lots of power issues (brownouts, blackouts, etc), don't bother with anything expensive.
Originally posted by: George P Burdell
I guess a basic UPS can protect against surges and brown-outs.
Originally posted by: sdifox
You have to define what is in your HT first.
Originally posted by: spidey07
I just use a heavy duty power strip.
As already noted, avoid using a UPS.
Originally posted by: YOyoYOhowsDAjello
How much did you spend on your HT?
I'd have a hard time spending $700 on a power conditioner unless I knew I had sh!tty wiring that was causing problems.
EDIT: looks like some places have it for well below MSRP ~$250?
Originally posted by: Rubycon
This kills power bugs dead. Plenty of hold for the transfer switch for the diesels. Never be without power again. (or a second mortgage hehe)
Plasma ran me $1450.
I can get this unit for $150 at ecost.com
We have one of these at work. Just slightly overkill for my needs![]()
