Power Problem with RCA-RT2500 Home Theater System
Idz21
310
Hey all,
I have had the RCA RT2500 Home Theater System for about 4 years now. When it was working I hardly ever used it, but when I needed to it worked. :)
One day, about 8-10 months ago, I was unable to turn it on. I thought it was weird and figured something was up with my surge protector. So I switched electrical ports and voila, it turned on and worked fine. A couple of weeks after that it wouldn't turn on again, so I tried a bunch of different plugs - even directly to the wall. Nothing worked.
The strange thing is that when I plug it into power I can see the little red light turn on in the 'power button' - or remote receiver. So it's definately getting power, but there's something wrong with the power mechanism or something. I tried unplugging all speakers from it - still no go. I took the cover off and re-plugged some power switches - still no go. Maybe there's not enough juice to power the system. :confused:
Does anyone have an idea of what I can do to fix this myself? Maybe someone has the same receiver and ran into the same problem. It figures that the $300 receiver goes bad as soon as my $100 3 year warranty runs out :(
This might not be the correct forum to post this, so if anyone can point me to a forum which deals with these types of things directly. I posted the same thread on doityourself.com
AlienCraft
10,539
Power switch may be bad. Or the speaker protection relay circuit is bad. Either one will prevent it from turning on.
If you're competant, open the case and with a jumper, jump across the terminal the power switch has and see if it powers up.
Otherwise, decide if you want to spend a few bucks to repair or if you want to toss it and buy a new one.
Idz21
310
Not sure what you mean when you say, "with a jumper". I would like to ideally fix this myself. When I opened up the case I couldn't notice anything wrong with it.
