camswinton
I have a new USB microphone that seems to be causing problems. Occasionally it won't be powered(or recognized) after a reboot. Frequently when this happens, the other device on the same USB controller doesn't work either. I currently have 6 (including microphone) USB devices plugged-in (2 printers, scanner, card-reader, palm dock, microphone).
Is it possible that my power-supply is maxed out? Would a powered USB hub fix that or would a new PS be the best choice? The other thing I'm considering is that the USB mic. is faulty (although it works fine when recognized).
My system in a nutshell: Intel 2.6c w/Abit IC7 MB, 2x512MB DDR, 2 HD's, CDRW, DVD, Antec 300w Smart Power PS (came w/case).
SpeedFan shows my voltages as follows:
+3.3V: 3.28V
+5V: 5.05V
+12V: 12.10V
Note, the system is otherwise rock solid.
I don't want to return the microphone as faulty if my problem is power related. Your help would be appreciated!
+3.3V: 3.28V
+5V: 5.05V
+12V: 12.10V
