- Jan 3, 2001
- 12,650
- 207
- 106
A few hours ago my neighborhood had a momentary power outage that lasted only for a couple of seconds. My daughter who lives right down the street called me a little later to report that her computer wouldn't come on.
System
Epok 8k7a Mb
1800+ XP Processor
128 MB DDR 2100
Matrox G400 Dual Video
She has brought the computer to me and this is what I have found.
Upon bootup, all fans are spinning [Power Supply, CPU Cooler, Onboard Chipset, and case fan].
The monitor never flashes or shows a cursor...nothing appears on the monitor [have tried different monitors]
After it runs for a few seconds a noticeable electrical burn smell that seems to be coming from the the CPU area.
The motherboard displays a "3C" POST CODE. I looked at the CPU and it did not appear to be burned up but I must say I'm not really sure what it would look like if it did. It is definitely not burned up like the pictures I've seen when an AMD is allowed to run without a Heat Sink and Fan. There may be a little darkness to one side of the chip that runs the whole length of that side. I would need to get my digital camera back from a friend who borrowed it to let you see a picture of it.
Since I had one available, I changed the Power Supply out for a known good one.
Next attempt to bootup gave the same results. I allowed it to run for almost a minute to see if I could see smoke or detect anything else that might be the problem when the motherboard turned itself off...probably a safety shutdown of some sort.
I have again removed the CPU and it appears to be the same as before.
I looked up the "3C" POST CODE and the manual says, "Set flag to allow users to enter CMOS Setup Utility." I didn't understand how that could have anything to do with the problem unless it is just the point of the bootup where the process halted. I cleared the CMOS and tried once again and again got the same results.
Does this sound like my CPU may have been damaged during the power outage (fluctuation?)?
I do have a 1900+ XP system with the same motherboard. If I was going to try parts from one to the other, in what order should I proceed? I would certainly hate to lose my perfectly operating 1900+ XP system.
[edit] A little update. I have opened up my 1900+ XP system and the CPU has the same dark area that I described on the 1800+ XP ... they look identical in that regard.
I would apprecate your help.
System
Epok 8k7a Mb
1800+ XP Processor
128 MB DDR 2100
