dannyboy731
Hello all, maybe someone can figure this one out. So about a week ago my computer started having trouble powering on. When I turned it on, I didn't get the usual mobo p.o.s.t. beep, the monitor would not power on, and the hdd light would stay on constantly. Also, the reset button had no functionality, but I could still hard reset with the power button. Then I found if I flipped the power switch on/off on the psu, it would then boot up fine, but only if I had tried to power on once and failed first.
Phase two of my problems - any time I try to do anything at all memory intensive, the comp cuts off, hanging at the same half-on, fans running, monitor off spot. I can replicate the restart pretty consistently with photoshop or while running winamp and firefox at the same time. It will restart 100% of the time if I try to import a cd in iTunes, but sometimes gets through one or two songs, sometimes half of one. It all works pretty much as normal if I don't do much other than use the internet or check my e-mail.
So here is what I have tried already...everything on the internet so far had pointed me towards a failing power supply, overheating cpu, or bad ram. I changed out the ram first, no help. I made sure all of my fans were still working and cleaned out some dust, no help. Last, I ordered a new, slightly better psu, and replaced it to no avail. My thinking now is that I might try replacing the mobo and/or cpu; I can't really think of anything else.
I can't really see how this would be caused by a software problem, and I've checked pretty thoroughly for viruses and spyware. I hadn't really made any changes to my system around the time this all started, either. The last thing I did was replace a dead hdd about 3 months ago. Anyway, this thing has pretty much been a lemon since I got it, and I know I need a new system, I'm just holding out for tax refund time. So yeah, any help will be greatly appreciated, and I apologize for the lengthy post. Thanks a lot!
