Under the Power Management control panel, there's usually a field where you can select your monitor's shutoff settings, like if you want it to shut off after 15 minutes of inactivity and the like. Well, there isn't. I'm stumped. Any ideas on how to fix this? I'd rather not to a clean reinstall of Windows. Would installing Windows on top of itself fix it maybe?
