- Sep 28, 2001
- 8,464
- 155
- 106
I am not the only one who complained here about the silliness of today's overclocking and the stupid throttling down for no apparent reason.
I found countless complaints on other forums as well which more or less confirm to me that something "is off" with Nvidia/Kepler throttling down for weird reasons.
ONE thing I found is ALSO an inconsistency using Afterburner, Precision, NV Inspector or ANY tool which allows setting the "power limit" level.
For example I can set power limit to 100% and see normal clock rate, set it to only +1 it clocks down 200-300, set it one more it goes back to normal and so forth.
The set "power limit" is NOT consistent and sometimes clocks down the card "erroneously" at some values.
It could, therefore, well be that people use those tools like Afterburner, NV inspector etc. and set a power limit and then see their card throttling/downclocking where it shouldn't. Try it, just use one notch more or less and see it corrects itself again.
(Right now I see it downclocking at each ODD number, but this is not consistent either. The next time I start Afterburner the same thing happens with each EVEN number. Result is therefore that you never know in advance whether you get to to "wrong" PL number where it downclocks, UNLESS you monitor and know what your normal clock rate is supposed to be).
At least this is the case here with my 660 TI and drivers 341.22
