justin4pack
So I just received the last of my parts for my ITX build. I wanted to make sure temps were ok in the little box so I ran 3dmark vantage. Around 1 minute in the whole thing shut off and rebooted. So I figured it was to hot (GTX 590) so I took the lid off and tried again. Same thing. So this time I put a fan next to the outtake on the front of the 590 because it expels heat from the front as well as the rear. I run it again and same thing. So I checked event viewer and it shows "Kernal-Power" Task 63.
So im not sure if its the PS or the video card is getting to hot. I ran afterburner to monitor temps and the max it was getting was 80c which for that card is pretty normal.
This is the Power supply http://www.newegg.com/Product/Produc...82E16817438007
