Hey all,
I just bought a neo 2 platinum and a amd 64 3200.
I put the memory, cpu on the board and connected the power switch. We turned it on to check something with the fan.
The problem is that as soon as I turn on the back power, the whole board starts up.
If I hit the power switch, it will turn off. But if I hit the power switch again it doesn't turn back on. I have to unplug and replug the power cord and then it will just turn on again and do the same thing.
Here is what I have tried
-took the board out of the case and tried it on the static bag
-Tried to change sids on the power switch connector in case it was in backwards.
-unpluged everything else but the power switch.
Still does it no matter what.
I am using a 480 watt PS with the setting at 115.
Could it be the board? or maybe the power supply?
Any help would be greatly appreciated.
