Power Issue...continued
StixBaraca
Well...After trying many many things...I removed the mobo from the case and fired it up. It ran with no problems, which tells me the mobo is getting grounded on/in the case. Now to only figure out the best way to stop that! Once again thanks to all the replys! jackschmittusa to you I owe a nice cold :beer: CHEERS!
Try hot gluing some plastic or fiber washers to the bottom of the mobo where the mounting screws go through.
. Make sure you are using only the holes that are designed for mounting - usually have a tinned rim around them.
.bh.
:beer: time!
Back to the idiot check...Always make sure any non used mobo/case brass stand offs are removed! The system is now completely functional and up and running...time for another :beer:
