Power Cooler Fan
queyan
135
Hi
I'd like some feedback on this socket a cooler. At the moment, I am waiting for my duron 600 to arrive. It is a Power Cooler model no. PC2100. I copied from the power cooler website, www.powercooler.com.tw, the specs on this cooler. Is this an good a cooler to OC the processor? Thanks in advance for any replies.
Fan:?? 70?~15 mm
Rated Voltage: 12V DC
Speed: 5000?}10% RPM
Air Flow: 18.0CFM
Noise: 33dBA
Heat Sink Dimensions:??70?~ 45.5mm
CPU SURFACE TEMP. ( ?? ) ( Tj ) 70.5 73.4 77.8
CASE AMBIENT TEMP.( ?? ) ( Ta ) 45.0 45.0 45.0
?¢T( ?? ) ( Tj-Ta ) 25.5 28.4 32.8
P ( W )(Max proc thermal power) 35 40 45
R ( ??/ W ) ( ?¢T/P ) 0.729 0.710 0.729
(Thermal resistance )
tonyou
508
The cooler you are talking about is being marketed in the U.S. as "Copper Orb," you can find more info here. According to Kyle's review at HardOCP, it maybe risky to use on a Socket A processor. This heatsink appeared to be more suited for Socket 370.
Tony
