Power conversion differences between countries
isasir
8,609
Does anyone know of a good link that explains the differences between the electrical power ratings of the outlets in diff't countries?
I'm going to Europe in a few days, and I'd like to bring my AA battery charger (for my digital camera) to Europe, but most converters seem to be rather pricey, for what I need it for.
Zim Hosein
Super Moderator | Elite Member
65,293
403
What specific country in Europe are you visiting isasir?
Eli
8
What exactly do you mean?
Think of it this way. In Europe, everything is like your dryer. You wouldn't want to go plugging your battery charger into your dryer's outlet without some sort of adapter now, would you?
OK, well, you might have a gas dryer.. but whatever.
USA = 120V, 60hz.
Europe = 240(220?)V, 50hz.
kami333
5,110
Check your charger, many are able to handle 100-240v 50-60hz. Then all you need is a $2 plug converter.
halik
25,696
All of europe uses 220V
Countries on the main land use a plug that looks like this (o o)
England has a plug that looks like this { _ | _ }
isasir
8,609
That's what I'm trying to figure out. I don't have the charger with me right now, but there was a bunch of power ratings on the back of it, and there's a good chance it did say 100-240v, 50-60hz on the back. I'd love to be able to just buy a $2 converter.
isasir
8,609
USA = 120V, 60hz.
Unfortunately that's the problem. I'm a bit naive with this electrical stuff and even though I shouldn't, my dumb ass might just plug in my charger into my dryer's outlet...
fbrdphreak
17,555
As the others said, check the power rating. If its 220-240 50-60Hz, buy the plug adapter and you're AOK.
Sphexi
7,280
I assume this would be the adapter I'd need if the power ratings can handle 220V?
Yes, but it's not yet in the stores. There was an older special order version of it, but they dropped it and replaced it with a store stock version, but didn't ship it out yet. So yes, that is the correct plug, but no, Radioshack doesn't have any of them.
isasir
8,609
Cool. Too bad no Radio Shacks near me apparently have it. :( Uh, what's a good alternate store to check?
isasir
8,609
No wonder any zip code I typed in yielded no results. Why wouldn't such a converter be more popular, so it wouldn't need a special order? It's not like it's uncommon for people from the US to visit Europe.
Sphexi
7,280
Like I said, it's not available. Don't ask me why, I have no idea. It's what's called a D2U product, special order from the stores, yet the warehouses have none.
*shrugs*
Just look for a similar one online, or call a travel agency, they tend to have them.
Czar
you can probably get them at the airport as well
Sphexi
7,280
It's extremely popular, I used to keep 10+ on hand at all times. Yet the company yanked the one I had in the store and replaced it with an identical unit but through a different method of ordering. They did this a few months ago, and have yet to get it in. Pretty pathetic actually, but nothing new.
http://electricshavershop.com/nwg-1c.htm
Same type of thing, but you can actually get ahold of it.
