- Jun 3, 2004
- 15
- 0
- 0
Say if I have a 60 watts light bulb, it means that it uses 60 watts of power per hour, right?? does that work the same as power supplies??
Dr. Pizza is right. I've found the best way to look at units is to consider what they actually represent.Originally posted by: Springdalewater
uhhhhhhh.........watts=volts*amp
I thought joules is work done, and the formula is joules=volts*columb??
amp=columb/t
Blah, physic sure is confusing.
Originally posted by: DrPizza
A watt is a joule per second
What 60 Watts means is that your lightbulb is consuming energy at a rate of 60 Joules per second.
The confusion with hours probably comes from the way you are charged for energy usage: by the kilowatt-hour
A kilowatt-hour is 1000joules/second*1200seconds or simply 1.2 Megajoules of energy.
Maybe what you mean is that it uses 60 watt-hours of energy?
edit: perhaps consuming is a bad word.
So, a 60 watts light bulb consumes 60 watts per hour?? or per second??
Make that 3600 seconds, and 3.6 MJ
It might be helpful to look at it like this. "Watt" is a rate, just like miles per hour is a rate. Your car goes 60 miles an hour - how many miles does it go in one hour at this rate? 60. Exactly the same logic - how many Joules (the measure of energy, just as mile is the measure of distance) are expended if you run something at 60 Watts for one hour? Recalling that one Watt = one Joule per second, 60 Joules/second*60 seconds/minute*60 minutes/hour = 216000 Joules = 60 Watt-hours = 0.06 kiloWatt-hours.Originally posted by: Springdalewater
Originally posted by: FrankSchwab
Lot of confusion on power supplies here....
The PSU rating is their maximum output; in almost every case, they will be outputting (?) significantly less than their rating. They will be consuming (from the wall outlet) something like 10 to 25% more power than they are providing due to inefficiencies in the supply.
Thus, a 600 watt PSU providing 300 watts to a (very high end) system, will be consuming 330-375 watts from the wall outlet.
/frank
Useless? USELESS? Imagine the tens of millions of little girls (and boys) who would have been deprived endless hours of fun with their Easy-Bake Ovens if it were truely 'useless'.Originally posted by: Peter
Lightbulbs in turn consume their rated wattage, with comparably abysmal light output. Most of the energy comes back out as useless heat.
It probably consumes around 500HPLet's say the engine in your car makes 200HP. Does it consume 200HP per hour?
:light:
