Power consumption of a 9800 non-pro?
Lonyo
I have a GF4 Ti4400, and I'm getting a 9800 np, but I only have a 300w PSU, made by HEC (IIRC), so I was wondering how much more power the 9800 needs, because I'm worried my PSU might not be able to handle it.
Originally posted by: MercenaryForHire
You'll be fine. Hardly any typical PC users ever tap the well of a 300W PSU.
- M4H
Unless you're heavily overclocking your CPU. I've found (along with ThugsRook, Duvie, etc) that if you have a P4 over 3 GHz, you will want at least 430W to get the highest overclock. In my opinion, quality 350W PSU's (ie the Enermax) do quite sufficiently also.
Athlons can be a bit more forgiving since they get their CPU current from the +5V rail, which typically is given more current than the +12V one (which the P4 uses).
I`m 90% sure that a 9700pro uses 54W. So say about 60W for the 9800s.
You should be ok if your PSU is a quality one. But if i was you, i`d save up for a new PSU. 350W+.
