Power connectors
Ryder401
177
How important is it that I have all 4 power connectors plugged in? (I have a DFI Lanparty nF4 SLI-DR Motherboard)
Zepper
18,998
You should only need the basic two (ATX and P4-12V) unless you are using what the other connectors are intended for. IOW, if you're not running a pair of vid cards in SLI, then you don't need that. If you're not running any PCIE cards, then you don't need to connect that.
.bh.
Jiggz
4,329
If you got them connect them. They will only draw power if they are required anyways.
