Originally posted by: spp
o and can someone help me find out the difference between 1250VA and 600VA of APC line-R products?? THe specs are similar while one is heavier than the other.. i'm guess just better parts?
Originally posted by: MWink
Any Line-Interactive UPS will condition power. Stand-By UPS's are the only ones that do not condition power. I suggest you go for the APC Back-UPS Pro 420 or 650. They have the best line conditioning capability of all the UPS's I've used. Line conditioning has nothing to do with Sine Wave output. The difference between the two Line-R's is their max capacity.
so would a power conditioner work fine or should i go for a ups?? i basically just want to have stable voltage level
Are you sure? Or do you have some money burning a hole in your pocket and you need something electronic to buy?Originally posted by: spp
i'm thinkign about getting a power conditioner because the voltage of my outlet varies a lot
I really think it's worth it to spend the extra on a UPS. I still consider my 4 year old APC Back-UPS Pro 650 to be one of the best investments I've made.
If your power fluctuates then wouldn't the solution be to physcially fix the line problem rather than condition the output?Originally posted by: spp
well my monitor fades in/out a lot in my room... but was fine in my roomate's.....
and plus i measured it using a voltmeter..
could you elaborate more on why you think it's better than just power conditioner?? i guess i'm choosing between the two (while one is a lot more expensive than the other).
thanks
hmm... so i guess i should get an ups.... but it's so expensive though....
